RSO not fully working with VC
RSO 5.09.02 does not appear to work fully with any of my virtual controllers. only real controllers fuly work OK.
FlexPendant viewer is not working, UAS administration not working, and unable to 'enalble edit'. all virtual controllers are using the same revision of baseware as that came with RSO. this has been working in the past but not now, is anyone else noticing this behavour.
what am I doing wrong ?
  • I have also unistalled and reinstalled and get the same behavour.
  • I also note that when logging off form the VC within RSO and Logging back in as a different User... there are no different users shown in dropdown list, and so only the default user is the only login available.
    If this default user has limited access then how do you disable UAS in a virtual robot.
    Once the default user has been limited in one Virtual controller all my l virtual robots appear to have this same behavour.
    Is there a work around. if a real robot I would use hyperteminal and choose the comand 'UAS disable'
