IRB6600/2.8-175&IRB6650/3.2-125
Hello RalphZheng!
All available robotmodels for RobotStudio are found at http://www.abb.com/robotics then goto //Product Range //CAD-models // and then search for your robot model.
To get the model working you also need to upgrade your RobotWare, for customers with Subscription Service it is found at:
http://solutionsbank.us.abb.com/ goto DownloadBank//Robot Products and Systems // After Sales Products
If you don't have access to Solutionsbank you will have to contact your local Robot Supplier to get the latest version of RobotWare.
Hope this helps you!
Best regards
/Ulrika
Support Engineer
Administrator37896,52975694440 -
It works now! Thanks a lot.
Ralph
