API: TargetReachEvent
Hi again!
I found a TargetReachEvent EventHandler in the Mechanism class.
I did
[code]
int targetsReached = 0;
myactiveTask.Mechanism.TargetReachEvent += new EventHandler(myTargetReachEventHandler);
[/code]
with
[code]
static void myTargetReachEventHandler(object sender, EventArgs e)
targetsReached++;
[/code]
When I do Simulation -> Play the robot reaches all the targets but the eventhandler is not called.
Can anyone tell me whats wrong?
Best regards, Matthias
  • Hi Matthias,
    Unfortunately the TargetReachEvent isn't implemented, so it will never be called..
    regards,
    Johannes
    Johannes Weiman
    Software Engineer
    ABB Robotics
