problem with serial channel
pawel
I have problem with serial channel "com2". The robots are connect with serial channel and I want data tansfer it. I hane two robots irb140 and irb1400.
When I send data from 1400 to 140 ... it is all right.
But when I send data from 140 to 1400 does not come.
Serial channels are set same, it is ok?Well thanks for all responses.
Pawel
pawel2008-3-17 23:14:57
what instructions do you use?
as usual writebin paired with readbin
Peter0
