Reading Variables Sample Project [WebWare SDK]
Note: If you downloaded the previous sample that was attached here, it did not include the correct robot program. Attached below is an enhanced version that includes the correct robot program.
This is an extremely simple project that demonstrates the process of reading controller variables from a Visual Basic application.
Additionally, the data being accessed is of the S4XData type, a RAPID variable object that can be used to access non-atomic data via Interlink.
The zip file contains the VB project, the compiled .exe, the necessary robot program, and a readme file describing how to use the contents.
RussD38078,8765162037Russell Drown
