RS License
I'm having a problem with starting RS when not connected to the network. Everything works ok when connected to the network. The error message I get is:
"No valid application license (Error code 80040212).
Do you want to launch the License Key Request Wizard to obtain a valid license)"
Sounds similar to the problem posted previously on this forum.
http://forums.robotstudio.com/forum_posts.asp?T ID=1443&KW=robotstudio+license
However I am unable to run as administrator and I am using Windows XP OS.
Thanks in advance,
Neil
neil2007-12-13 11:15:53
  • Hi Neil.
    Please send us your lservrc file, so we can check it.
    You will find it using this path: C:Program FilesCommon FilesABB Industrial ITRobotics ITLicensing
    Also generate a new License Key Request Form from your computer and send back to us.
    To;  softwarefactory_support@se.abb.com
    Thank you.
    Tonje Sandberg
    Service Training Coordinator
    ABB AB / Robotics Products
