Supervision of flanks
How do I detect the positive flank of a signal going from 0 to 1?
  • There are at least two ways to do this on IRC5
    1) Use the Interrupt/TRAP mechanism in RAPID to take some action in response to the transition of your signal from 0 to 1.
    2) Create a FlexPendant SDK application that "subscribes" to the IO changed event for your signal, then take some action when the signal changes AND its value is 1.
    Method 1 is simpler and likely faster than method 2 because you can configure the interrupt to happen based upon your desired state change, i.e. 0 to 1, and also the change event does not need to be broadcast to a client device (the FlexPEndant).
    Russell Drown
  • Thanks Russ.
    I went with the first alternative (trap routine), but of course im having probs also with this.image My problem is the trap routine is never carried out. I connect the intvariable with the traproutine in Mainroutine and i deactivate it immediately. then i want to activate it in my Grip Routine and again deactivate in release routine. Can you see something wrong?
    Here is the code:
    In Datamodule:
    VAR intnum DetailMissingCylFwd;
    VAR intnum DetailMissingCylBack;
    In Mainmodule:
    PROC Main()
    CONNECT DetailMissingCylBack WITH DetailLost;
    IsignalDI iGripperCylBack,1,DetailMissingCylBack;
    CONNECT DetailMissingCylFwd WITH DetailLost;
    IsignalDI iGripperCylForward,1,DetailMissingCylFwd;
    isleep DetailMissingCylBack;
    isleep DetailMissingCylFwd;
    PROC Grip()
    (code for gripping)
    iwatch DetailMissingCylFwd;
    iwatch DetailMissingCylback;
    PROC Release()
    (code for releasing)
  • Found it... image
    The signal to trigg my interrupt was already 1 when the interrupt was activated. image
    Thanks.
