Kinematic Limitation Error
billv
I'm receiving an error 50209 "Kinematic Limitation" when moving to some work objects. As a resolution, the message displays an option to 'Increase position and orientation tolerance'.
How do I do this?
It also displays "Insert an intermediary point, Check Singularity, Use MoveAbsJ, Check working range." But I'm simulating an existing system in RobotStudio and rather not change any of the code.
Thanks
