API: Create and attach tool from geometry
I am trying to create a tool from a geometry.
There is an Xml-file with the data I need for the tool.
It stores the path to the Cad-file, its center of gravity, its position in the wrist coordinate system and so on.
I can import the geometry from a given CAD-model via
[code]
GraphicComponentLibrary gcl = GraphicComponentLibrary.Load(reader.GetAttribute("path"), false);
station.GraphicComponents.Add(gcl.RootComponent.CopyInstance ());
[/code]
I can also create a tool with data from an Xml-reader via
[code]
RsToolData tool = new RsToolData();
tool.ModuleName = "Module1";
tool.Name = reader.GetAttribute("name");
tool.RobotHold = true;
tool.Frame.X = Convert.ToDouble(reader.GetAttribute("x"));
tool.Frame.Y = Convert.ToDouble(reader.GetAttribute("y"));
tool.Frame.Z = Convert.ToDouble(reader.GetAttribute("z"));
tool.Frame.RX = Globals.DegToRad(Convert.ToDouble(reader.GetAttribute("rx")) );
tool.Frame.RY = Globals.DegToRad(Convert.ToDouble(reader.GetAttribute("ry")) );
tool.Frame.RZ = Globals.DegToRad(Convert.ToDouble(reader.GetAttribute("rz")) );
//Create the loaddata for the tool
RsLoadData myloadData = new RsLoadData();
//Set mass
myloadData.Mass = Convert.ToDouble(reader.GetAttribute("mass"));
//Set center of gravity
myloadData.Cog = new Vector3(Convert.ToDouble(reader.GetAttribute("cogx")), Convert.ToDouble(reader.GetAttribute("cogy")), Convert.ToDouble(reader.GetAttribute("z")));
//Set the Axis of moment
myloadData.Aom = new Quaternion(Convert.ToDouble(reader.GetAttribute("aomx")), Convert.ToDouble(reader.GetAttribute("aomy")), Convert.ToDouble(reader.GetAttribute("aomz")), Convert.ToDouble(reader.GetAttribute("aomw")));
//The load can be considered a point mass, in this example, i.e. without any moment of inertia
myloadData.Inertia = new Vector3(0, 0, 0);
tool.LoadData = myloadData;
//Show the name of the tooldata in the graphics
tool.ShowName = true;
//Show the tool data in the graphics
tool.Visible = true;
//Add the tool data to the active task
station.ActiveTask.DataDeclarations.Add(tool);
[/code]
There are some problems I could not solve:
  1. How can I attach the geometry to a robot? In Rs it is just drag&drop, but with the API...?!
  2. How can I connect the RsToolData with the geometry?
Should I load the geometry as a Part?
Part has a method called attach, but I have no clue how to use it image
Is this possible with the API?
Best regards and a happy new year,
Matthias
  • Hi Matthias,
    To attach a tool to a robot you can do like this:
    actStn = Project.ActiveProject as Station;
    Mechanism mechRobot = actStn.GraphicComponents["MyRobot"] as Mechanism;
    GraphicComponent grTool = actStn.GraphicComponents["MyTool"];
    IAttachableChild attachTool = grTool as IAttachableChild;
    mechRobot.GetFlanges()[0].Attach(attachTool, false);
    ABB Robotics
  • Hi again!
    Thanks for your help!
    Now  I have
    [code]
    GraphicComponent gc = gcl.RootComponent.CopyInstance();
    gc.Name = reader.GetAttribute("name");
    station.GraphicComponents.Add(gc);
    Mechanism mechRobot = station.GraphicComponents["IRB4400_60_196__01_2"] as Mechanism;
    GraphicComponent grTool = station.GraphicComponents[reader.GetAttribute("name")];
    mechRobot.GetFlanges()[0].Attach(attachTool, true);
    [/code]
    When I attach a tool to a robot manually in RS the TCP changes automatically.
    Can I do this within a Plugin?
    Best Regards, Matthias
    Matthias2008-1-7 13:51:38
  • Hi,
    when I use my plugin the tool is attached to the robot, but no new TCP is created.
    When I detach the tool (right click on tool in Objects-window -> detach, without keeping position)  and then re-attach it (right click on tool -> attach to,  also without keeping current position) the right TCP is created.
    How can this be? Is there any solution?
    I guess I can specify the TCP by
    [code]
    IAttachableParent parent = mechRobot.GetFlanges()[0] as IAttachableParent;
    parent.attach(attachtool, true, offset);
    [/code]
    If that is the solution, how can I get the offset? The offset is loaded when I import the *.rslib, but I don't know how to access it.
    Best regards, Matthias
    Matthias2008-1-9 11:2:56
