Using the S4Array object [WebWare SDK]
Here is a simple example of using the S4Array object in VB6. The code illustrates the following tasks:
  • the creation and configuration of the S4Array object
  • populating the object with data from a controller variable
  • changing data values within the S4Array using the Element1 property
  • writing the changes back to the controller
Update:
Attached is an improved version of the S4Array sample.
B7E_VB6_S4Array.zip
RussD38068,8362268519
Russell Drown
