API samples in VB .net
Options
john_yu
can anybody post some API samples written in VB .net? thanks in advance.
John
john_yu2008-1-11 22:2:80
Hi John,
Check out the VSTA template project "RobotStudioSample". It's available in both C# and VB.NET and contains some basic samples.
regards,
Johannes
Johannes Weiman2008-1-14 14:8:31Johannes Weiman
Software Engineer
ABB Robotics0 -
thanks a lot.0
I've tried to look at the vb sample in "RobotStudioSample", but I get a load of errors. The first one is this:
Warning 1 Load of property 'RootNamespace' failed. The string for the root namespace must be a valid identifier. RobotStudioSampleProject
I suspect that this is then causing the others.
Any ideas?
Regards and thanks in advance,
Andrew0
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 348 IRC5
- 74 OmniCore
- 844 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
