Get axis data
Klaus
I try to use the example on page 175 in the userguide.
Dim AMechCol As MechanicalUnitCollection = aController.MotionSystem.MechanicalUnits()
Dim AMechUnit As MechanicalUnit = aController.MotionSystem.ActiveMechanicalUnit
I get error from both lines.
Error 1 'MechanicalUnits' is not a member of 'ABB.Robotics.Controllers.MotionDomain.MotionSystem'.
Error 2 Value of type 'String' cannot be converted to 'ABB.Robotics.Controllers.MotionDomain.MechanicalUnit'.  ;
What do i do wrong?
Best regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hello Klaus,
This example works for the PC SDK. In the FP SDK, however, there is no MechanicalUnits property, but a GetMechanicalUnits method, so this is obviously an error in the User's Guide, which will be corrected.
If you take a look in the FP SDK Reference Help you will see a correct example:
Controller c = new Controller();
MotionSystem motion = c.MotionSystem;
MechanicalUnitCollection mecUnits = motion.GetMechanicalUnits();
foreach (MechanicalUnit m in mecUnits)
if (m.Name == "ROB_1")
// Do Something
}Best regards,
Ingela Brorsson
Software Engineer
ABB Robotics, Sweden0
- 400 UpFeed
- 20 Tutorials
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 350 IRC5
- 74 OmniCore
- 848 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
