Is there a cfg file for IRBT4004?
I imported IRBT4004 and tried to create a system from layout.
Then I was asked where the cfg file was and I couldn't find it.
Yu
  • Hi Yu,
    To create a system for the IRB4004 you must use the additional options mediapool Track.5.09.0010 that is installed with RobotStudio. The mediapool supports RobotWare 5.10.xx. Add the additional option to the system and select the Track variant you want to use in the System Builder. When the system starts you must manually point out the variant of the track you want to use. To get all the variants of the IRBTx004-tracks installed you must do a custom installation or a full installation. Unfortunately, "Create System from Layout" does not support the IRBTx004 family. This is also described in the release notes of RS 5.10.
    Kind regards,
    ABB
