Install RAB
Hello ,
I have installed VS2005 Standard on my PC.
I installed RAB, but when I go to new project... there is no Flexpendant project to Start!
Any ideas what the problem is??
Thanks in advance
Adolf
Adolf Wieser
  • Hi
    I had the same problem with the italian release of VisualStudio 2005, I just removed it and installed the English release.
    Regards  Gianluigi
  • RAB has only been tested with the English version of Visual Studio, so if you are running Visual Studio in any other language I recommend that you switch to the English version so that you are running in the tested/supported environment.
    If you still want the project to appear in Visual Studio of another language you need to manually copy the projects to the correct language folder
    For C# copy from:
    *ProjectTemplatesCSharpSmartDeviceFlexPendant1033
    For VB copy from:
    *ProjectTemplatesVisualBasicSmartDeviceFlexPendant1033
    Where * is read from the registry in (VS2005)
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftVisualStudio8.0Insta llDir
    I think that German for instance is 1031...
    Then using the VS command prompt you can use "devenv /installvstemplates" commands to make VS read them at start up.
