Backup with different Robotware Versions
Matthias
Hi!
We are trying to restore a system from a backup created with Robotware 5.10 on a robot with Robotware 5.08.
The process aborts with the message that a config file is corrupt.
Do we have to install Robotware 5.10 on the robot to be able to do the restore?
Best Reagrds,
Matthias
Best Reagrds,
Matthias
If I did know what the future would look like I wouldn't be sitting here writing on this forum :-)Forward compabilty may work, but in most of the cases it doesn't.
So you what can you do1. Install the matching RW
2. Just load the program modules and not the config files. I think the problem is the moc.cfg so you may be able to load the eio.cfg but I'm not sure.
Per Svensson
Consat Engineering0
- 364 IRC5
- 82 OmniCore
- 37 AppStudio
