License key fault
HI
i have updated from RS 5.09 to  5.10 but after installing the new licensefile i get this message.
What can i do to correct the problem ??
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
  • Hi Hardikez
    Please analyze the computer with the enclosed analysis tools, to help us locate the problem.
    2008-02-29_135721_License_Diagnostics.zip
    There are 1 tool enclosed in the enclosed ZIP file (3 files):
      LicenseDiagnostics.exe
      Interop.LicenseManager.dll
      lsapiw32.dll
      LicenseSupport.dll
      Run LicenseDiagnostics.exe tool following the instructions below and send screen shots back to ABB.
    LicenseDiagnostics.exe:
    The tool, LicenseDiagnostics.exe, is designed to complement the Software Product Administration tool.
    The new tool supplies more detailed information on a license with the internal license error codes from the licensing system.
    Installation:
    Copy and Unzip the LicenseDiagnostics.zip on your desktop of your PC. (Or other if prefered)
    Use:
    Start the "LicenseDiagnostics.exe".
    This will open a window which is similar to a Promt Window.
    Let this run (can take a little while) and when a new window comes upp save the new file in the same place you unzipped the LicenseDiagnostics.zip
    Press any key to remove the prompt window.
    Send the file created; LicenseDiagnostics.xml   to  softwarefactory_support@se.abb.com
    BR // Tonje Sandberg
    ABB Robotics
    Industrial Software Products
    Tonje Sandberg
    Service Training Coordinator
    ABB AB / Robotics Products
