WWS CustomDB Tables [WebWare Server]
in WebWare
FYI
If you are defining your own DataTypes in RAPID (option developersfunctions in the Robot needed) be sure that the name of the Record type you define only have lowercase letters. Otherwise the creation of the database will not work.
Working example:
RECORD mydatatype
num errNum;
string errDescription;
ENDRECORD
Not Working example (D and T can't be Uppercase):
RECORD myDataType
num errNum;
ENDRECORD
Per Svensson
Company Specialist
ABB Automation Technology Products
Company Specialist
