Application Error
When I am attempting to open a new system in RS, I am able to save to a file path and select my robot, etc.  However before the controller begins to initiate, I receive an error that says:
An application error has occurred and a support log will be created.
Information about the problem will be written to: c:...
However, this file path does not exist and immediately afterward RS crashes.  Not sure what is wrong or how to fix, any thoughts?  Thanks.
Michael VanHout
  • Hi
    I suggest that you try Direct3D instead of OpenGL as render.
    You change that in menu toolsOptions and then GraphicsRenderer.
    Per Svensson
    Consat Engineering
  • seems to have fixed the problem, thank you!
