Macros and Graphics in C#
Hi All!
I am working with VSTA programming a macro that makes an object disappear by becoming more and more transparent, and then a new object appears becoming less transparent in the same place :)
I have a problem because I have to repeat this procedure in different phases with different objects, and it is getting complicated.
I am using TemporaryGraphics because it is the only way I found to draw and object with transparency, but they have lots of limitations, for example I cannot remove only one, so I cannot make it disappear...
Is there a better way to do this? Can I add transparency to one part?
Thank you very much in advance for your ideas and help!image
Anna
Best Regards,
Anna
  • Hi Anna!
    Have you tried to remove a temporary graphics objects like this?
    Station
    s; Part p;
    TemporaryGraphic tempGfx = s.TemporaryGraphics.DrawPart(Matrix4.Identity, p);
    s.TemporaryGraphics.Remove(tempGfx);
    Best Regards
    Niklas Skoglund
    Best Regards, Niklas Skoglund
    ABB Robotics
    Developer Center
    RobotStudio Blog
  • Hi Niklas!image
    Thank you very much for your help, I think I can see the problem now, but I don't know how to solve it yet! image
    I was working with GraphicComponents because I cannot create/declare a TemporaryGraphic as you do in your example, it is not a reserved word (it does not appear in the list and it does not turn blue) maybe I have to use another reference? image
    Anna
    Best Regards,
    Anna
  • Ok I've got it!
    I had to add:
    using
    ABB.Robotics.RobotStudio.Stations.Forms;
    I used the object browser to see where the TemporaryGraphics were, I'd had never thought that I was missing something, because I was using already the TemporaryGraphics...
    Thanks again Niklas!
    Anna
    Best Regards,
    Anna
