Search in RS with Flexpendant [ArcWelding PowerPac]
Check out the product documentation for the Smartac option 3HAC024845-001
SmarTacT is a tactile sensor used to find the location of inconsistent weld joints and offset the programmed points in a weld program. The main rapid instruction used for this option is Search_1D.0 -
Please see the attached user doc for SmarTac.
ABB0 -
I know how to do in the real robot flexpendant, i would like to do it with the flexpendant i RS.
my problem is that i RS there is no search routines when i try to make the PROCALL to the search 1d routine.
Is it possible to get the search routines in the RS flexpendant
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com0 -
You must add the SmarTac option to the system also on the VC.
ABB0 -
hi
the smartac is already in the controller system
So i dont understand why the searchroutines is not found on the flexpendant i RS
Kent Zibrandtsen
Hi Hardikez,
It seems that the Search_1D instruction must be added to the "Most Common" list to be used from the FlexPendant. Please follow the instruction on p29 of the SmarTac manual.
Kind regards,
Henrik
ABB0
