Syntax : %RoutineName%;
Maddin
Hello all,
First I want to say Hello. My Name is Martin and im new on this forum.
I have a couple of questions to you Experts.....Hope you can help me
We are using a Pickmaster and a Robot IRB 6650 to handle parts.
In the programm (Main Routine) there is a syntax i've never seen before:
%RoutineName%;
I cant find a subroutine or any variable with this name. Do you know this syntax
Regards Maddin
The syntax is the RAPID version of late binding, in which you make Procedure call to a method that is either not loaded yet (in conjunction with the Load instruction) or if you want to call the prcedure as a variable value.Russell Drown0
thanx for the prompt response.
I understand. I just cant find neither a procedure or a variable with this name in the hole backup.
But there is a cryptet system-module which i can not view.
proberbly its deklared in there.
Thanx anyway
Regards Maddin
