IRC5 NFS Client
bryce268
I am trying to use the IRC5 NFS Client (baseware 5.09.5) to mount a drive on a PC running windows XP and the Omni NFS server version 4.3.
It is behaving unreliably at best, although I think my configuration is correct since it does work some of the time.
If I warm start the robot then it comes up with an error and won't connect. Several minutes after that it will randomly come up and work correctly again. So far I have been unable to pin down anything that has an effect on this behavior.
Has anyone else had similar issues with the NFS client on IRC5?
Thanks
Thanks
