S4 controller with OS V2.13
Does anyone have any ideas on how to run robot studio using an S4 controller with OS V2.13? The problem I am having is this version does not have a "backup" function to make a .bak file to restore to the virtual controller and the installation floppys do not have a KeyID file to install from key.
Aarick Danielson
Waupaca Foundry
  • Well, do you have any idea what robotware options the system has? If you don't I would say just check as many options as you like in RS, and test back and forth with loading the RAPID program.
