Error Record grafic
I get this messeges when trying too use record grafic.
I found a post from DanS with the same problem and the answer was that there was tool litle free space on the C drive. I have 24 gb. I have also 1 gb off free memory soo what cann bee wrong it worked 2 weeks ago i use 5.10
RobotStudio .NET exception dump
Base exception:
Der er ikke tilstr?kkelig lagerplads til at udfore denne handling.
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRIn ternal(Int32 errorCode, IntPtr errorInfo)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHR(I nt32 errorCode)
at ABB.Internal.RobotStudio.API.APIHelper.ThrowApiExceptionIfBa dHr(Int32 hr)
at ABB.Robotics.RobotStudio.ScreenRecorder.Start(String filename, IntPtr hWnd)
at ABBInternal.GeneralCommands.ScreenRecorderGUI.docStart_Execu teCommand(Object sender, ExecuteCommandEventArgs e)
at ABB.Robotics.RobotStudio.Environment.CommandBarButton.RaiseE xecuteCommand()
Klaus Soenderhegn
www.cadalysator.dk
The problem is solved. I had to remove RS and indstall again and now it works. But it's noting to do with free space on c drive. there is another problem just as you know
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hello Klaus,
The movie is recorded to the temporary directory which may not be on the C: drive. I would be interested to know if that is the case on your system. You can check this by opening a command prompt and typing
echo %TEMP%
thanks,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
