Problems with weld templates. [ArcWelding PowerPac]
I am having problems with weld templates in arcweld. I have set up some weld templates which worked fine in version 5.9, but does not work in 5.10.
Specifically, when we convert to weld the correct zone data is not applied.  Also the options Conc and Corr in the template could be set to disabled or enabled in 5.9, but 5.10 gives the option of enabled or "blank" - could this be the reason?
I loaded SP1 hoping it might solve the problem but no joy.
anybody any ideas?
Thanks,
Jed Ginnever - farrel ltd
  • Hi Jed,
    Is the problem you see isolated to AWPP or do you see it when you modify instructions in RobotStudio?
    Henrik Berlin2008-4-16 13:8:23
    ABB
  • We seem to be able to modify instructions in robot studio OK, which does help to some extent but ideally we want the correct zones etc to be brought in when we use AWPP.
    Thanks
  • disabled was changed to blank in 5.10. We thought that was easier to see.
