Virtual Arc Problems [ArcWelding PowerPac]
I have been trying to test out virtual arc and have been running into problems with it. Whenever I try to do an analysis it gives me the following errors:
1) mllapack.dll procedure is missing
2) dgbtrf procedure is missing
3) predict_weld.exe failed to execute
The analysis just stops and freezes virtual arc.
Has anyone else had these problems?
-Ben
  • Hi Ben,
    Do you have a version of MATLAB or MATLAB Runtime Engine previously installed?
    Henrik Berlin2008-5-26 13:43:27
    ABB
  • Hi Henrik,
    No, MATLAB has never been installed on this system.
    Ben
  • Hi,
    Please check if you find the file mllapack.dll in the folder
    C:Program FilesMATLABMATLAB Component Runtimev76inwin32
    Kind regards,
    ABB
  • Henrik,
    mllapack.dll is in the folder you specified.
    Thanks,
    Ben
  • OK, please check that the path above is added to the PATH system environment variable, see attached picture
    2008-06-03_114935_Path.zip
    ABB
  • Hi, i built an aplication in .NET and Matlab, obvious I have matlab in my computer but mi DLL is'nt registred, you know why?
    thank u
