Geometry Import
BioTop
Hi people,
I need to import a geometry file (Step) in wich entities are NAMED in a Part, and I need to keep the names within RobotStudio.
I double-checked that names are currenlty in the file ( by text editor and it's fairly ok if I import it in Solidworks ...) but I never succeeded in importing it in RS5.10, either directly of through CAD Converter (even playing with parameters) without loosing names.
Is there a way to do it or RS simply replace every name by 'Corps' ?
It's wonderfull, it's wonderfull ....
