Positioners logical axis number
Options
sturner
I want to use a RS 5 generated program in an S4 robot...
The problem is with the logical axis number for the Ltype positioner. IRC5 uses 11 (eax_e) and the S4 robot uses 8 (eax_b).
I thought that I could change the parameters, but it appears that the the MOC.cfg, which contains 'Joint': logical axis number, is read only and a Backup does not include this either.
Any ideas?... Thanks in advance for your help.
Simon T
it isn't possible to change encrypted parameters, so you either must change the index in the RAPID program or ask for new external options media for the L-positioner
magu0
- 400 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 348 IRC5
- 74 OmniCore
- 844 RAPID Programming
- 21 AppStudio
- 109 Collaborative Robots
