multimove on track
I have made a system with 2 coordinated multimoved IRB4400/60 from the eksampel i the helpfile.
I have also made a system with one IRB4400/60 on track from the eksample in the helpfile.
Both works fine.
If i make a multimove system with 2 coordinated Irb4400/60 and one track i get an error when i load the cfg file that match the track.
See atahed file.
2008-05-13_113715_Error_track_with_multimove.zip
I use RS 5.10.2370.146
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
The error you see is related to the RobotWare configuration and not RS.
Just a couple of stupid questions:
* Do you want to have the track in Task1 or Task2?
* What track model do you use? IRBT4003, RTT or IRBT4004?
* Did you add an additional axes drive unit for the track in the task of the track?Note 1: For IRBT4004 you need to have the track in the first task and use the Track.5.09.0010 mediapool (include it when building the system in system builder).
Note 2: For RTT and IRBT4003 you must use one of the supplied configuration files. You must select the one corresponding to the correct task, i.e. if you use a track of length 5.7m in task 2, then load the parameter file TRACK_5_7_Task2.cfg
ABB0 -
...and
IRBT4004 is not yet supported by "Create System From Layout" so you need to create the system manually for that one. On the other hand it uses a dynamic model for the track which means improved motion performance and reduced cycle time.
ABB0 -
[QUOTE=Henrik Berlin]
Hi Klaus,
The track ig IRBT4004 and the cfg file was fore task1.
The RW is 5.10.146.00
I will try to make a new system but have 2 RW in 5.09
5.09.01_1020 and 5.09.99_166
and not the one wrote.
I have add the drive as shown in the help file end the add the cfg file to the system in RS after.
Bets regards Klaus
[/QUOTE]Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Greate Henrik It worked with robotware 5.09.1020.01
Great support thanks for your help.
But i'm going to order this setup tommorow. Is there a problen with the real robots and RW 5.10?
Best regards Klaus
Best Regards
Klaus Soenderhegn
The mediapool Track.5.09.0010 also supports RW 5.10 contrary to what the name suggests. I believe the same setup will work also for real robots. The system will be exactly the same. There is a later version of the Track mediapool available though, and I suggest your ordered system will use the later one. There should not be any major changes though.
ABB0
