Real IRC5’s system options on the V IRC
Options
What should I do to creating system in Robotstudio with options from the real IRC-5. Where can i find ROBOTWARE KEY and DRIVER KEYS. Is it to possible to download every settings and options from IRC-5 to Robotstudio??
  • You can build a system from a backup or look in the file BackInfokeystr.txt to get the keys to build your system.
    Some options will not work correctly on virtual systems, for instance File and Serial Handling, because there is no physical hardware for the system to use.
    Russell Drown
