Add-ins in 2008
Hardikez
hi
I have a add-ind made for RS5.
I have tryed to import it to rs2008 but i cant se it active any where.
what is the problem?
Kent Zibrandtsen
Dept manager robot welding
Kez@hardi-international.com
Hi Kent,
If you put the dll in BinAddins it should be visible in the Add-in tab. Is there any error message in the output window?
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
