write acces
If i sync to VC in RS 2008 then i cannot delete the module from the CV again
in RS5 i could" request write acces" and then delete the module.
how can i do this in the new RS2008??
Dept manager robot welding
Kez@hardi-international.com
The mastership handling (write access) is suppressed when working with a VC. This means that RS should take write access automatically when needed. In Online mode though, mastership handling is explicit and controller by the user.
Consequently, you should be able to delete the module in Offline mode. RS should take mastership automatically. If this is not the case, then it is a bug.
Henrik Berlin2008-5-27 13:38:53Henrik Berlin
ABB0 -
When I open RS2008 and go directly to "Off line" window and open my rapid module it is impossible to delete the module from the VC.
I have realised that it is only possible through the Flexpendant.
Guess its a bug
Kent Zibrandtsen
Kez@hardi-international.com0 -
Please upload a pack & go of the failing station so that we can have a closer look at the issue.Henrik Berlin
ABB0 -
Check that the controller is in Auto mode otherwise you won't be able to delete the module.Per Svensson
Consat Engineering0 -
hi
I have realised that i had a fault when i loadet the station, and this was the reason for the the problem.
Kent Zibrandtsen
