simulation
hello, i have some geometries, like screw, conveyor,etc. can i simulate them in robotstudio? if yes, can i make it move(simulation) without the robots? and how to simulate it?
i have some project that i have to make robot moves accurate and synchronize with the screw and conveyor, but i don't know how to make the path so accurately and synchronize.
can somebody help me?
thanks before!
To move an object on for example a conveyor, the best is to create a mechanism of the conveyor, and then use the event "Move Mech To Pose" to move the object. You will find information in the RS Help about how to create a mechanism and use the Event Manager.
If you use a "Station Signal" to trig the event, you don't need a robot system in the station.
ABB Robotics0 -
thank you for your helps, anders. it's very helpful
now, i want to simmulate the robot to pick up a box. i see the i/o simmulation movie from http://library.abb.com/global/scot/scot241.nsf/veritydisplay /d7bf0f0992638187c1256b9d00285c07/$File/io_simulation.avi
but, i can't find the signal and the value from the SETDO instruction.
i try to create the instruction template and create SETDO, but i find many error. actually, i don't know how to fill the signal and value from the arguments
. the error is looks like picture below.
i have read the rs help, but it doesn't help. how to fill the arguments?
thanks a lot
regards,
indah carmila0 -
You have to add the I/O signals to the Robot System yourself. I/O signals can be configured in RobotStudio Online, which you can start from the Program menu in RS. In the RobotStudio Online Help will you find information about how to configure new I/O signals, or load an existing configuration file (EIO.cfg).
To be able to control the signals from RS, the "signal access level" has to be defined to "ALL". I have attached an EIO.cfg with two DO and two DI signals that you can load into your system.
ABB Robotics0 -
hoho..., thanks anders!!
now, i can simmulate it.
thankyou for your help.thankkss!!!
regards,
indah carmila0 -
Hi, you could add signals in an easier way by using virtual flexpendant (" pressing F5 ") go to control panel - configuration -signal .. don't forget to turn the irc5 into manual mode by pressing little icon that looks like irc5 and flag the middle button .. (mr Jetman tips)
thank you for your tips! it's very helpfull !!
regards,
indah carmila0
- 40 AppStudio
