connecting other device to robot
carmila
hi, i have some question (..again..!)
- i use the screw(with rotary) and a sensor. robot will move if it receive the trigger from the rotary and the sensor. so, how i connect them?
- can the controller of the robot handle all of my mechanism?(sensor activation, processing the pulse from rotary, and so on --> like PLC)
many thanks for your helps.
indah carmila
is there any relation with using the instruction template?
indah carmila0
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
