Extended Compliance Tool
Hi all RAB Programmers image
Here comes a Windows Application for running the Compliance Tool so that you don't have to bring up a command prompt.
This product is not offically supported but issues/improvments can be posted here and if I have the time I will try to solve/implement them.
You net to have .NET Framework installed to be able to run the app but I guess if you are developing RAB applications you allready have that.
ABBCompTool.zip
Per Svensson
Company Specialist
ABB Automation Technology Products
  • Hi Per
    I have tried your tool, it works fine
    but I had some initial problems with the path to CSC.exe
    See Ya Later
