help me out
hi friends
i m totally new to robot studio
i m using rs 5.09 from 2 days and i can make a path
but wen i play it change its direction..... it doesn't go througth the given path plz help me
my company need it
im regular user of PRO-E Wildfire 2
plz send some tutorails or notes which it will me in makeing it perfect
on my mail vibunews@gmail.com
thanks in adv......
hi every one thats "Vj"
  • Hi
    There is a tutorial build in to robot studio have you run that ?
    You shod  upgrade to 5.10 it is included in your license.image
    Regards
    Knud Erik Lindberg
    Jorgensen Engineering
  • hey thx Knud E Lindberg
    for reply
    last day i tried a lot then came to know that the configration
    was wrong
    and as u said tutorail...... it don't work here proper or its too less toturail to understd conscept.......
    plz tell me
    and i came with another prob here
    hw can i move or rotate the object as per my robotarm
  • hi if you right click on one of your external axes you will have to choose mechanism joint jog.
    you can then move the slider back and forth, feks on a track, robot or what ever.
    is this what you meen?
    Kent Zibrandtsen
    Dept manager robot welding
    Kez@hardi-international.com
  • hey thanks buddy......image
    not mech joints jog
    if i'm keep my job on positioner then how can i move it
    revole as shown in demo
    plz.....
    today i mail some question to ABB robotic but they did't replyed yet
    do u know any valid email id where i can send it
    so i can solve over there only
    as i can't take out anything from company......
    so give me an email id plz.........
    thanking u image
  • Just create a workobject and attach that to your positioner.
    The create your targets in that wobj and they will follow when yopu move your positioner around. Also if you want to do corrdinated motion on a positioner you need to do it this way and define that the positioner moves the wobj.
    Hope this was the answer to your question
    Per Svensson
    Consat Engineering
  • hiiiii friends.....
    thanks image for replying my problem
    as it was very imp
    i hve send query to ABB 4 to 5 times but did't they replyed yet
    Thanks to forum and the memnber also
    i have bought some question which we hve send it to ABB
    plz ...... my friends do.... reply on this
    sorry its to many but
    problem is ...... big problem ..........
    sorry again friends
    1- how to vary the speed of the robot as per our standard welding speed ?
    2- Gv us d complete information abt VIRTUAL FLEX PENDANT as how fast we can use it
    3- how to set program pionter, entry point for the task
    4- how to simulate robot & positioner simultaneously (synchronization)
    some error where i stuck in middle of the programimage
    a) the task T_ROB1 has syntax errors in its RAPID program
    b) synchronization to VC failed? what should i do...?????
    c)program pointernot available....????
    d) could not set program pointer to entrypoint for task T_ROB1image
    f) the program could not be started
    plz tell how to over come  like this errors
  • hey friend s
    tell me frankly
    should i must stick on RS
    or leave it aside
    bcoz it goiung tough day by day
    and my company need results from me
    and i don't have enough knowlegde on this
    they only hv s/w no any manual to read it go through it......
    plz help me out
    if i must stick on it wat should i do for bettter results
    thanks for reply
  • Hi
    I can see that you have many questions and ma by a training in robotstudio will be good for you. If You go i to :
    www.abb.com/robotics and send a mail to Arvind Vasu in India, he can inform you of the nearest robotstudio training center.
    Regards
    Knud Erik Lindberg
