Mechanical Cut User Guide
AndyB
Can anyone tell me if there is a User Guide for Mechanical Cut (PDF Form), like the ARCWELD PowerPAC??
I have search a number of sources but with no success.
Thanks in advance.
Andy B
A *.chm-file is included in the Mechanical Cut PowerPac. It's installed automaticaly. Although this might not be a PDF-file or a printed manual, it is basicaly the same. You can compare it with the *.chm-file which comes with RobotStudio itself. When you compare that file with the manual of RobotStudio, you'll find that they both contain the same information.
The *.chm-file for Mechanical Cut can be found here:
...Program FilesABB RoboticsAddinsMechanical CutMechCut.chm
Or you can download it from here:
Good Luck
<@Logan> I spent a minute looking at my own code by accident.
<Beeth> And your point is?
<@Logan> I was thinking "What the hell is this guy doing?"0
