Autosave
Klaus
Autosave is the best thing in RS soo you don't loos to much work when it chrashes....but can it also contain backup of the controller?.
3 times my RS has chrased to day and each time i loos rapid code because autosave dont make a backup.
Where is the rapid code placed in the VC.
Can it be restored after chras? My VC is still runing can i get it from there?
PLZ !!!
BEst regards klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk
Klaus Soenderhegn
www.cadalysator.dk
Hi Klaus,
Just try opening the station again. If the VC is still running, RS should automatically connect to it rather than start a new instance. If you open the Rapid editor your code should still be there.
regards,
Johannes
Johannes Weiman
Software Engineer
ABB Robotics0
