Replace text
Thilbi
where is a problem in the replace-function.
I would replace a pattern of text with the option "Search in: Current system". Now the RS replace the text not only one time at all positons, it replace the text many, many times. My instructionline increases from 70 columns to 3620 columns. So often RS insert the new text.
Best regards
Thilbi
Best regards
Thilbi
Hi Thilbi,
Thank you for reporting the issue to us. This will be corrected in the 5.11 release.
ABB0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 337 IRC5
- 67 OmniCore
- 831 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
