Interfacing with serial port on IRB6600
I've been having trouble interfacing with the serial port on my IRB6600 robot. I have an ADC (http://www.omega.com/pptst/D1000.html)
with serial output that is hooked up to COM1. The ADC requires a $1RD
command to request data from it, so I'm trying to send that string to
the serial port, and then read the data value that comes back. When I
try and run this program, it hangs on the line that tries to read the
serial port. Can anyone tell me what's wrong?
ENDMODULE
Code:
MODULE Controller
VAR iodev com_port1;
VAR string signal;
PROC GetSignal()
OPEN "COM1", com_port1BIN;
While True Do
WriteStrBin com_port1, "$1RD";
ReadStrBin com_port1, signal;
TPWrite signal;
EndWhile
CLOSE com_port1;
Try This:
WriteStrBin com_port1, "$1RDD";
Also, I Beleive "ReadStrBin" is a fucntion with a return value of the type string;, not an instruction as you show in your code. Please check the RAPID Reference Manual for examples on how to use the following:
ReadStrBin function and/or ReadAnyBin instruction -
You will want to figure out how to use the function to be able to determine when the EOF occurs by reading one character at a time.
What version of baseware and/or RobotStudio are you using?
It should have complained about your syntax...
Thomas J2008-6-25 1:53:56Thomas H. Johnston
PACs Application Engineer0
