Parametric library part
Got a question about selfcreating parts with input parameters so I made this example:
Parametric_library_example.zip
Just import the library into a station.
It will build a small table from the users parameter choices.
If you wish to see the sourcecode:
Import the library.
Instead of clicking the OK button, click the close cross in the top right corner.
Right click the VBA_Library and select Disconnect from Library.
In the RS-VBA you will now find a project named VBA_Library.
image John
