Using Instruction "UIMessageBox"....
Use Systempack 5.10.1042 (Latest RAB)
I have a problem when I use the instruction "UIMessageBox" in combination with a active RAB application. When the "UIMessageBox" is active in a Multitask the operatorbutton has suppose to start blinking yellow, a indication for a operator to press OK from the UIMessageBox. The blinking is not starting when the RAB screen is active. When I jump for example to the production screen the operator next to the "ABB" button starts blinking!
Do someone has a soluition or do I need to wait for a new system pack?
Best Regards,
Edwin
  • Do you know for certain that this behavior has changed from previous versions of RW?
    Russell Drown
  • Sorry for the late reaction.
    The problem sometimes occured by other customers of ours but we did not know what it was. I am sure that is was the same in earlier versions. It is the same as in other versions but it is not ok.
    Edwin,
  • Hi Edwin,
    I was curious about this issue.  When you say "an active RAB application", do you mean a FlexPendant application that has focus on the screen when the UIMessageBox posts?
    /Bryan
    Bryan Johnson
    bryan.johnson@wolfrobotics.com
    Wolf Robotics
    4600 Innovation Dr.
    Fort Collins, CO 80525
    USA
  • Hello Brian,
    Yes that is correct, when for example the "Program Data" screen has acces it works ok!
    Greetings,
    Edwin
