class controller
TEUTON
Hi people! I have a new problem. This time is for another exception. I want to get some data of the controller's cpu, but when I acces member MainComputerServiceInfo of the controller object, the program throws a exception: GenericControllerException and the message of the exception is: the URL used to initialize the helper does not resolve to a valid object.
I saw the help of PC SDK, but there aren't much information. Please, help me. Can you help me?
Source code:
private void ConnectToController(object sender, MouseEventArgs e)
ListViewItem item = this.listView1.SelectedItems[0];
if (item.Tag != null)
ControllerInfo controllerInfo = (ControllerInfo)item.Tag;
if (controllerInfo.Availability == ABB.Robotics.Controllers.Availability.Available)
if (this.controller != null)
this.controller.Logoff();
this.controller.Dispose();
this.controller = null; ;
this.controller = ControllerFactory.CreateFrom(controllerInfo);
this.controller.Logon(UserInfo.DefaultUser);
MessageBox.Show("Te has conectado!");
ActualizarSenyal();
try
MainComputerServiceInfo infCPU;
infCPU = this.controller.MainComputerServiceInfo;
catch (ABB.Robotics.GenericControllerException ex)
MessageBox.Show(ex.Message);
else
MessageBox.Show("Selected controller not available.");
Thank you a lot.
Source code:
ActualizarSenyal();
try
else
Thank you a lot.
The property can only be used when logged on to a real RC, but I guess you know that...
Ingela Brorsson
Software Engineer
ABB Robotics, Sweden0 -
Thank you, but my program logs on to a real RC. For this reason I don't know what is happening.
Do you have the same major version of RAB, i.e. 5.10.x and RobotWare installed on the robot, as well as the runtime environment of the target PC? All of these components need to be the same version to ensure full compatability.Russell Drown0
- 40 AppStudio
