Offlineconfiguration
Thilbi
after i change a value in the a table of the Configuration, for example in the io-configuration, the first column shows small and you can't read the name of the io-signal. This is very restricting, because i need everytime a doubleclick on the top of the column to make the column in the right width to see the complete names.
Can you change this in the next version?
best regards
thilbi
best regards
thilbi
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
