RapidDataBinding source ???
I tried a simple example of using a RapidDatabinding source and it didn't work. I've consulted the user guide and sure i'm doing it right
Drag tpslabel to designer
Drag rapiddatabindingsource to designer
Set first element task, module and, variable to "T_ROB1", "MainMod", "nAnswer" respectively. (nAnswer is a persistent declared num in Module "MainMod" of task "T_ROB1"
I set the property of the label to use "on property change", and value, and this is linkd to the text.
Using the virtual flexpendant i change the value of nAnswer in the data types window.
Nothing happens??????
Are you using RW 5.09.0166? If so, there is a problem that affects only the VC. See this thread
http://forums.robotstudio.com/forum_posts.asp?T ID=1604&KW=event
Russell Drown0 -
What a rookie move
Thanks RussD, of all the robotware versions i have, i had to install the one that stuffs up. D'Oh!
Again thanks!
- 361 IRC5
- 79 OmniCore
- 853 RAPID Programming
- 30 AppStudio
