Launchview
Hey everybody,
i'm really a Rookie in RAB and i've got a question, hope you guys can help me out....
I want to edit a special "pos" in the "Program Data"
I try to do this about a Button! If i click the Button the programm should launch to the "Program Data/pos/pos1" surface, so that i can edit the pos.
How can i do that in VB (not C#) ?
By now i try it with this command, but it didn't works:
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click
Me.ARapidData = Me.AController.Rapid.GetRapidData("T_ROB1", "MainModule", "pos1")
Me.FpRD = New FpRapidData(Me.ARapidData)
Me.FpRD.Text = Me.ARapidData.Name
AddHandler Me.Button4_Click, AddressOf Button4_Click
Me.FpRD.ShowMe(Me)
Hope someone can help me out with a right syntax example !
Thanks "7"
Try this:
Dim ctrl As Controller
Dim f As FpRapidData
Dim rd As RapidDomain.RapidData
Private Sub btnLaunch_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnLaunch.Click
Try
rd = ctrl.Rapid.GetRapidData("T_ROB1", "user", "pos1")
If Not rd Is Nothing Then
f = New FpRapidData(rd)
AddHandler f.Closed, AddressOf FpRapidDataClosed
f.ShowMe(Me)
Else
GTPUMessageBox.Show(Me, _
Nothing, _
"Couldn't get RapidData", _
"RapidData Access Problem", _
Windows.Forms.MessageBoxIcon.Hand, _
Windows.Forms.MessageBoxButtons.OK)
End If
Catch ex As Exception
Nothing, _
ex.ToString, _
"Exception", _
Finally
rd.Dispose()
rd = Nothing
End If
End Try
End Sub
Private Sub FpRapidDataClosed(ByVal sender As Object, ByVal e As EventArgs)
RemoveHandler f.Closed, AddressOf FpRapidDataClosed
If Not f Is Nothing Then
f.Dispose()
f = Nothing
End If
End SubRussell Drown0 -
Thanks for your answer
Mmmh, but it didn't work by now.
When i click the button there is an Error Message:
System.NullReference Exception:
"The Objectreffering is not set on an objectinstance"
I've read in the users guide.pdf : Using the
FpStandardView enumerator, the following standard views can be started using
the launch services: Program Data...Is there maybe a way to Launch direct to the Programm Data Window with the Variable that i want to Edit? For example, a End-User must edit a pos variable, so i want to launch by a button click direct to this window where the end user can edit the variable.
Grettings "7"
It works for me, exactly as you described above, i.e the Data Viewer is launched, seeded with the RAPID variable pos1.What version of RAB and RW are you using?
This wasn't an entire application, it is only the click event handler for a button that launches tha data viewer. You must make sure that you adjust the object names and the RAPID variable names to work with your app, otherwise it should work.
If you continue to have problems, please attach the stack trace so that we can see where the null reference is coming from.
Russell Drown0 -
Hey Russ, once again thanks for your help so far, but i still have the problem. Here's my complete Programm, i'm nearly sure i've done everything right, but i still have the error message. The funny thing is that i can jump to a specify row in a Module with the RapidEditor initdata function, but the GetRapidData thing won't work....
By the way i'm using RAB 5.10 & Robotstudio 5.10.
Here's my complete programm, maybe you see what's wrong, i'll keep on trying
' ABB namespaces
Imports ABB.Robotics.Tps.Taf
Imports ABB.Robotics.Controllers
Imports ABB.Robotics.Tps.Windows.Forms
Imports ABB.Robotics.Controllers.RapidDomain.RapidData
' Compliance Tool Info
<Assembly: ABB.Robotics.Tps.Taf.TpsView("test7", "tpu-Operator32.gif", "tpu-Operator16.gif", "TpsViewtest7.dll", _
"TpsViewtest7.TpsViewtest7", StartPanelLocation.Left, TpsViewType.Dynamic, TpsViewStartupTypes.Manual)>
Public Class TpsViewtest7
Inherits TpsForm
Implements ITpsViewSetup, ITpsViewActivation
Private iTpsSite As ITpsViewLaunchServices
Friend WithEvents Button1 As ABB.Robotics.Tps.Windows.Forms.Button
#Region " Windows Form Designer generated code "
Public Sub New()
MyBase.New()
'This call is required by the Windows Form Designer.
InitializeComponent()
'Add any initialization after the InitializeComponent() call
End Sub
'NOTE: This is where you clean up any remaining resources used by your application before
'the application itself is disposed of by TAF (TeachPendant Application Framework).
'The method is called by TAF when the application is closed down.
Protected Overrides Sub Dispose(ByVal disposing As Boolean)
If Not IsDisposed Then
Try
If disposing Then
'ToDo: Call the Dispose method of all FP SDK instances that may otherwise cause memory leak
End If
Finally
MyBase.Dispose(disposing)
End Try
End If
End Sub
'NOTE: The following procedure is required by the Windows Form Designer
'It can be modified using the Windows Form Designer.
'Do not modify it using the code editor.
<System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
Me.Button1 = New ABB.Robotics.Tps.Windows.Forms.Button
Me.SuspendLayout()
'Button1
Me.Button1.BackgroundImage = Nothing
Me.Button1.FontName = New ABB.Robotics.Tps.Windows.Forms.DesignerFont("Font12b")
Me.Button1.Location = New System.Drawing.Point(101, 118)
Me.Button1.Size = New System.Drawing.Size(264, 145)
Me.Button1.TabIndex = 2
Me.Button1.Text = "Button1"
Me.Button1.TextAlign = ABB.Robotics.Tps.Windows.Forms.ContentAlignmentABB.MiddleCen ter
'TpsViewtest7
Me.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Inherit
Me.BackColor = System.Drawing.Color.LightGray
Me.Controls.Add(Me.Button1)
Me.Size = New System.Drawing.Size(640, 390)
Me.Controls.SetChildIndex(Me.Button1, 0)
Me.ResumeLayout(False)
End Sub
#End Region
#Region " ITpsViewSetup Members "
'NOTE: This method is called by TAF when the control is closed down (before Dispose is called).
Sub Uninstall() Implements ITpsViewSetup.Uninstall
'TODO: Add TpsViewtest7.Uninstall implementation
End Sub
'NOTE: This method is called by TAF when the control is installed in the framework (after the constructor is called).
Function Install(ByVal sender As System.Object, ByVal data As System.Object) As Boolean Implements ITpsViewSetup.Install
'TODO: Add TpsViewtest7.Install implementation
If TypeOf sender Is ITpsViewLaunchServices Then
' Save the sender object for later use
Me.iTpsSite = DirectCast(sender, ITpsViewLaunchServices)
Return True
End If
Return False
End Function
#End Region
#Region " ITpsViewActivation Members "
'NOTE: This method is called by TAF when the control goes from the active state to the passive state,
'and is no longer visible in the client view. This happens when the user presses another application button
'on the task bar, or closes the application. Normally, any subscriptions to controller events are removed here.
Sub Deactivate() Implements ITpsViewActivation.Deactivate
'TODO: TODO: Add TpsViewtest7.Deactivate implementation
End Sub
'NOTE: This method is called by TAF when the control goes from the passive state to the active state,
'i.e. becomes visible in the client view. Normally, this is where subscriptions to controller events are set up.
Sub Activate() Implements ITpsViewActivation.Activate
'TODO: Add TpsViewtest7.Activate implementation
End Sub
#End Region
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Try
f.ShowMe(Me)
Else
GTPUMessageBox.Show(Me, Nothing, "Couldn't get RapidData", "RapidData Access Problem", Windows.Forms.MessageBoxIcon.Hand, Windows.Forms.MessageBoxButtons.OK)
End If
GTPUMessageBox.Show(Me, Nothing, ex.ToString, "Exception", Windows.Forms.MessageBoxIcon.Hand, Windows.Forms.MessageBoxButtons.OK)
Finally
rd.Dispose()
rd = Nothing
End If
End Try
End Sub
f.Dispose()
f = Nothing
End If
End Sub
End Class
Grettings "7"0 -
Ok, I see your problem. You need to instantiate the controller object somewhere in your code. Usually this is done in the install method.
ctrl = New controller
you can also do it in the declaration:
Dim ctrl as new controller
It is not necessary to add the ITpsViewLaunchServices stuff unless you want your application to be launched by another application.
You should also see the section on disposal to make sure that you clean up all of these references when closing your app.
Russell Drown0 -
Ohh, how embarrassed is that for me
I only instantiate the controller like this:
"Dim ctrl as controller" and forgot NEW! The compiler said that's Ok, but didn't work without the "new" in front of the controller ...
Yeah, now it works!
Muchas gracias Russ
