multitasking
carmila
i want to create the program that make the robot move, in other hand, along the movement, i also must check the sensor. if there is a problem, the movement will stop / something, according the type of errors. Can RS do application like this? The error not only caused by one sensor, but maybe from several sensor. I think i will use the interrupt, but there are many interrupt program that I will use, so i think, if i use many interrupt, my main program will not executed.
so, are there any idea to solve it?
thanks before
indah carmila
- 20 Tutorials
- 303 PowerPacs
- 2.8K Robot Controller
- 353 IRC5
- 74 OmniCore
- 849 RAPID Programming
- 24 AppStudio
