Different Lettertype Real vs Virtual
Software: VC : 5.10
Real Controller : 5.10
I have the following problem. When creating a RAB application and watch it on the real controller the text in the screen looks ok. When I load this application in a Virtual controller the text is bigger! (See Picture)
The font I use in VS is Tahoma; 10pt.
Do anybody have a solution?
ScreenShot Real Controller
ScreenShot Virtual Controller
Text size may differ slightly between the real device and the virtual FlexPendant, but not this much! Have you found out what caused this appearance on the virtual FP?
Ingela Brorsson
Software Engineer
ABB Robotics, Sweden0 -
No, still have the same problem. Do you got the same problem? Do I use the correct lettertype?
Greetings,
Edwin
I have worked with several applications in the real & virtual environment, but never come across anything like this.
You should use the pre-defined fonts to save memory on the device, TpsFont.Font10 (= Tahoma 10). But I do not believe this is the problem. How come the first text in your screen looks the same in the two screenshots, but not the rest?
Ingela Brorsson
Software Engineer
I checked the font of the first to lines, it is "Microsoft Sans Serif; 9,75pt". This is working ok, but it's not ok for the memory then?
I will give it a try for the other lettertype's. Will be in 2 day's. Thanks for the quick reaction.
Greetings,
Edwin
Might have somethig to do with your desktop resolution, or maybe if you turn the Large Fonts setting on in your display setings.Russell Drown0
Hello,If I change the display properties of my laptop it does not make a different. Can I change something in robotstudio?I made a new screenshot. The highest label has the text property : Tahoma; 10ptThe lowest label has the text property : Arial; 10ptI tried to change the resolution and the Large Fonts settings, lucky for me it did not work! It is not a options to work with a low resolution for Robotstudio and change it for working with exel!What can it be????Best Regards,0
- 399 UpFeed
- 20 Tutorials
- 14 RobotApps
- 301 PowerPacs
- 406 RobotStudio S4
- 2.8K Robot Controller
- 339 IRC5
- 67 OmniCore
- 832 RAPID Programming
- 14 AppStudio
- 107 Collaborative Robots
