virtual flexpendant process
I think have found a bug in RS2008, the virtual flexpendant process do not terminate when the flex pendant is closed. This will block the past of new dlls to the home directory, when testing flexpendant sdk applications.
Knud Erik Lindberg
Jorgensen Engineering
[QUOTE=Knud E Lindberg]
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0 -
Hi Knud.
It's a old bug back from 5.08. You have to terminate proces in taskmaneger before copy DLL files to home directory.
I have notest that if you close your application on FP before close it it sometimes terminate, but not every time. I terminate FP from taskmanager erch time befor copy DLL.
Best regards Klaus
Best Regards
Klaus Soenderhegn
www.cadalysator.dk0
- 361 IRC5
- 78 OmniCore
- 852 RAPID Programming
- 30 AppStudio
