How to mask a num value?
I have a number of 104 (example, changes depeding on what the number I get from the PLC is). I would like to read the two last digits of 104 (04) and read that into a new num, is this possible in RAPID? Shearched but can't find anything regarding that.
Alexander K
AlexK2008-8-6 10:56:13
Best regards
Alexander Källberg
  • Hi Alexander,
    Try this:
    m = your original integer
    n = the two last digits
    n = m - Trunc(m  / 100) * 100
    Example:
    m = 1234
    m / 100 = 1234 / 100 = 12.34
    Trunc(m / 100) = Trunc(12.34) = 12
    Trunc(m  / 100) * 100 = 12 * 100 = 1200
    n = m - Trunc(m  / 100) * 100 = 1234 - 1200 = 34
    Disclaimer: This algorithm was not tested in RAPID and needs to be validated before put into production.
    Henrik Berlin2008-8-6 16:49:40
    ABB
  • Or something like this
    Per Svensson
    Consat Engineering
  • Thank you very much, need to put me into the above examples, I'm not a math genius, but I don't think it will be a problem, else I will bother the two of you again image
    Alexander K
    Best regards
    Alexander Källberg
